The switch doesn't work at all in acc mode (turning back) If you turn it "on" position, nothing happens until you turn it all the way over to start. When you let go, it springs back like normal but cuts the truck off. Now I can't get it to into gear without cutting off the truck. Would the problem be in the switch housing? I replaced the switch and still had the same problem.
Dec 1, 2009 at 5:57 AM
