1990 Ford F150 gas odor
145,000 MILES • V8 • 2WD • AUTOMATIC
RICHARD GAUER
I have two gas tanks. there is a gas leak above both tanks. Is there any tricks to finding the problem? I believe it is a hose or gasket on top of the tank. What is the precedure for removing the tanks. Any hidden dangers to watch for
Mar 30, 2009 at 7:18 AM
BLACKOP555
  • 10,386 POSTS
no tricks really. just take the tank down and check.
the only thing i can tell you is its a pain to get your hand in there to remove the lines and the electrical connector from the rear tank.
when you find the leak. use seal all to fix it.
it works wonders.
Mar 30, 2009 at 1:25 PM
