1990 Ford F150 fuel problems
154,000 MILES • V8 • 2WD • AUTOMATIC
NAPPER272007
I have replaced my front fuel pump,fuel pressure regulator,and the fuel relay switch, i am getting good pressure at the fuel rail and i am getting spark,but i am getting no fuel to my injectors. my turck turns over but will not start.it is the same if i switch to the back tank. what would cause my injectors not to get fuel?
May 25, 2008 at 12:49 PM
BMRFIXIT
  • 19,053 POSTS
check for injector pulse
check fuses and wiring
check TPS sensor
and computer
May 25, 2008 at 2:30 PM
