1990 Ford F150 clutch
135,000 MILES • V8 • 2WD • MANUAL
JOEM4
Hello
Thank you for your time. I was driving my 5 speed f-150 and the next thing i know after i pushed the clutch in it only came up half way it went into gear fine and everything and then i switched to the next gear and then when i let up on the clutch it stayed on the floor i could drive it but i couldn't shift anymore once i stopped i was done. i can take the pedal and lift it up and it will stay up but the second you put a little pressure on it it hits the floor. I can start it and everything when its on the floor i figured the clutch went out but I'm not sure. can you tell me if thats what it is or could it be something else its a hydrolic so i know there is no adjusting and i checked the fluid and it was full maybe theres a leak some where so i lost pressure i just don't know. Thanks for your help
Apr 9, 2008 at 1:51 PM
  • 31,937 POSTS
Hi there,
If the fluid level is OK, and you see no leaks in the hydraulic, you may of split a seal in the master cyl or slave cylinder.
Mark (mhpautos)
Apr 9, 2008 at 3:12 PM
