1990 Ford F-150 Blinkers
  • 1990 FORD F-150
Electrical problem
1990 Ford F150 Two Wheel Drive
My hazard and brake lights work but my blinkers don't. I have already changed the switch but that didn't work.
Sunday, August 8th, 2010 AT 2:21 PM
  • 110,055 POSTS
Do the lights come on at all? Also, have you replaced the flasher?
Tuesday, August 10th, 2010 AT 10:38 PM
Yes my lights work and all of my fuses are fine
Wednesday, August 11th, 2010 AT 5:14 PM
  • 110,055 POSTS
Have you replaced the flasher?
Wednesday, August 11th, 2010 AT 10:47 PM
I have changed the flasher but that didn't work either
Thursday, August 12th, 2010 AT 3:54 PM
  • 110,055 POSTS
If they are turning on but not flashing, I would check grounds since you replaced everything.
Thursday, August 12th, 2010 AT 11:36 PM
The lights come on but only for the brake lights and the hazards but not the blinkers.
Friday, August 13th, 2010 AT 12:57 PM
  • 110,055 POSTS
Have you checked all fuses? When you replaced the switch, was there power to it?
Friday, August 13th, 2010 AT 6:52 PM
