What is involved in changeing a straight 6 out and replace it with a v8 302? Trans is 5 speed.
Mar 25, 2010 at 2:06 AM
✓Experienced Mechanic
We recommend staying with a direct fit replacement. When you change, everything must be changed with it. You need, different motor mounts, vacuum harness, wiring harness, computer...
It can be done, but because of the amount of work and new parts you'll need, I don't recommend it.
Mar 25, 2010 at 6:19 AM
NASCAR BANDIT
MEMBER
Thanks guys, thatis what I was thinking. how about the bell houseing?
Mar 25, 2010 at 1:24 PM
THe trans should bolt up for you.
Mar 25, 2010 at 1:40 PM
