1989 Ford F150 Vapor storage canister
96,000 MILES • V8 • 4WD • AUTOMATIC
WBICHELL
Is there a way to safley bypass the vapor storage canister. I bought this old ford for cheap for use as essentially a farm use vehicle. It runs a bit rough and when I disconnected the vacuum hose from the VSC, it runs like a champ. contacting Ford, the VSC is $110.00 +/-...a good percentage of total vehicle cost.Thanks.
Jan 8, 2008 at 8:27 AM
BLACKOP555
  • 10,386 POSTS
you cant just bypass it like that! no matter what it just wont run right. Try a junk yard you could get one for 20 bucks more then likely.
Jan 8, 2008 at 10:26 AM
