1989 Ford F-150 temp. Sending unit.
DN_MARTZ
  • 1989 FORD F-150
Engine Cooling problem
1989 Ford F150 V8 Two Wheel Drive Automatic
my temp. Gauge stays in the cold mode at all times. I cannot find sending unit. I found temp. Sensor but not sending unit.
Monday, August 24th, 2009 AT 1:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Your vehicle's coolant temperature sending unit is located on the left front side of the lower intake manifold (for 5.0L & 5.8L engines) OR on the left front corner of the intake manifold (for 7.5L & Diesel engines).
Monday, August 24th, 2009 AT 1:55 PM
Test the coolant temperature sensor, and inspect wiring
https://www.2carpros.com/forum/automotive_pictures/12900_CTS_values_7.jpg
The reference wire that carries the 5 volt signal to the sensor will only read 5 volts if the sensor is disconnected. Any time the sensor is connected properly and the sensor ground is good, the 5 volt reference drops immediately. Usually, the voltage will be anywhere between 4 volts (very cold) to around .5 volt when the engine is fully warmed up. Room temperature will usually produce 2 to 3 volts (approximately 1/2 of the reference voltage). When the CTS circuit is open a scanner will read the coldest temperature that the computer can register in its program
Monday, August 24th, 2009 AT 2:04 PM
