My truck wont turn over to start. I have gone thru the starting system and tested or repaired all parts per the chilton manual. Replaced battery, replaced bat cables, replaced starter silinoid, checked starter (good), replaced ignition coil, replaced ignition module on the distributor body. Checked for connections for rust or corotion and if loose. Replaced ignition switch, checked fuses they were good. But yet the truck wont turn over. There is a clicking noise when you first turn on the ignition but the engine wont turn over. There is no clicking like the bats dead there is just nothing. The volt meter on the dash only reads about 9volts but the bat is new and I had it tested and it is good and strong.
SPONSORED LINKS
Sunday, September 6th, 2009 AT 4:18 PM
