1989 Ford F150 Relay or Switch problem
98,000 MILES • V8 • 2WD • AUTOMATIC
ALHAROLD
I bought a 1989 ford 150 and the switch when you turn on the fan won't blow. The one control Air Cond and Heater. I been told it could be a relay somewhere under the hood. Or it could be switch inside the truck. How can I be sure which one. The truck is V8 351 engine with air and automatic tranmission.
Sep 1, 2010 at 5:51 AM
  • 110,248 POSTS
Do any of the speeds work? Also, have you checked to see if there is power to the motor?
Sep 1, 2010 at 6:19 AM
