1989 Ford F150 no power
SAILJOCKEY
Electrical problem
1989 Ford F150 6 cyl Two Wheel Drive Manual 88K miles
truck quit running no power. lights do not work, horn doesn't work, won't start I turn the key and nothing happens. just had a new starter and battery installed. just dead in the water
Mar 5, 2008 at 12:57 AM
BLACKOP555
  • 10,386 POSTS
check for loose or corroded battery connectoins or a disconnected battery cable somewhere along the area.
if that isnt the case then you probably have a bad ignition switch.
Mar 9, 2008 at 6:38 AM
