1989 Ford F-150 no power
SAILJOCKEY
  • 1989 FORD F-150
Electrical problem
1989 Ford F150 6 cyl Two Wheel Drive Manual 88K miles
truck quit running no power. Lights do not work, horn doesn't work, won't start I turn the key and nothing happens. Just had a new starter and battery installed. Just dead in the water
Wednesday, March 5th, 2008 AT 8:57 AM
BLACKOP555
  • 10,371 POSTS
Check for loose or corroded battery connectoins or a disconnected battery cable somewhere along the area.
If that isnt the case then you probably have a bad ignition switch.
Sunday, March 9th, 2008 AT 1:38 PM
