1989 Ford F-150 locked gears
HANKMAN
  • 1989 FORD F-150
  • V8
  • 191,000 MILES
While changing ignition switch on the tilt column. I unbolted the column and now my gears are stuck locked in park and reverse, any idea what went wrong.
Friday, June 18th, 2010 AT 7:49 PM
  • 109,885 POSTS
That is a good one. I'm sitting here trying to picture what could have happened. The only thing that comes to mind is that maybe a bolt wasn't fully tightened and something is hitting. How much of the column did you remove?
Friday, June 18th, 2010 AT 8:57 PM
HANKMAN
  • 6 POSTS
Ijust lowerd the column to reach the ignition switch and change it.
Saturday, June 19th, 2010 AT 6:49 PM
  • 109,885 POSTS
You have to retrace your work. Something had to be put on a bind.
Saturday, June 19th, 2010 AT 7:16 PM
