1989 Ford F150 heater core hoses
1989 FORD F-150
MIKE1MONT
Heater problem
1989 Ford F150 Four Wheel Drive Manual 185000 miles
Hi
I want to install a tank heater on my f150, it has a 300 straight six cylindar for a engine. I need to know which heater hose is the return hose in it.
Thank You
Dec 8, 2007 at 9:45 PM
Disconnect both heater hoses from the heater core start it up and observe the hose that has pressure on it.
Dec 8, 2007 at 9:50 PM
  • 55,224 POSTS
Yep, that is the best way to see which way the coolant will flow, but I can tell you the hose closest to the water pump is usually the output.
Aug 2, 2024 at 3:52 AM
