I am trying to replace the head Gasket. I have romved everthing down to and including the Valve Cover. I see the vales and the bolts for the hjead with in there. I need to know if the head gasket replacement only requires removing those bolts and lifting ht head off, or is there more I have to remove including the center piece that the Thermostat is attached to.
Aug 16, 2008 at 10:57 AM
