1989 Ford F150 Gas gage
15,000 MILES • V8 • 4WD • AUTOMATIC
1BINGOBEAR
Dual Tanks. Both readings erratic and either pegs full or empty at about 1/2 tank.
Where is sensor located?
Any easy fix?
Oct 29, 2009 at 4:28 AM
  • 110,248 POSTS
Each tank has its own float. If they are both doing the same thing, chances are either the body control module (BCM) is causing it or the gauge itself is the problem.
Oct 30, 2009 at 1:17 AM
1BINGOBEAR
Thanks !
Oct 30, 2009 at 2:48 AM
  • 110,248 POSTS
Let me know what you find.
Oct 30, 2009 at 2:51 AM
