1989 Ford F-150 fuel pump
MIKE TOM
  • 1989 FORD F-150
Engine Performance problem
1989 Ford F150 V8 Two Wheel Drive Manual
I have a dual tank. Is the front tank internal or external pump?
If so, what is the other pump for?
Monday, October 6th, 2008 AT 7:57 PM
OBXAUTOMEDIC
  • 3,711 POSTS
You have 3 pumps one in each tank that are low pressure pumps. The one on the frame rail is a high pressure pump.
Monday, October 6th, 2008 AT 8:01 PM
MIKE TOM
Thanks so much for the quick response. I am thinking the high pressure pump is the one that has gone out. I have no fuel to engine, trying both pumps. When I do get it started, both pumps work. I can hear the pumps working and didn't think both pumps would go out at the same time.
Thanks so much for your help!
Mike
Monday, October 6th, 2008 AT 8:45 PM
