1989 Ford F-150
CSHELEY
  • 1989 FORD F-150
  • 6 CYL
  • 4WD
  • MANUAL
  • 130,000 MILES
I am wondering how to replace my power steering pump as it leaks profusely. Any thoughts?
Monday, December 31st, 2007 AT 12:36 PM
INDYUKE
  • 416 POSTS
You need to remove the serpentine belt, fan and fan shroud so you can reach down and unbolt first the power steering pump pulley, then the power steering pump itself. In some cases its easier to swing down underneath the truck and work from below because the power steering pump is bolted to the lower part of the engine block.
Tuesday, January 1st, 2008 AT 1:02 AM
