1989 Ford F-150 fuel leak
T57323
1989 Ford F-150 6 cyl Two Wheel Drive Manual
Last week my rear tank filled my front tank. Now I started it up and killed it, almost like I flooded the engine. It was acting like I needed a carburetor adjustment, but its fuel injected! I popped the hood and my girlfriend felt something leaking on her feet from underneath. There is gas flowing out of the charcoal canister. Mainly only from one of the caps, and not from the vabor lines, but when I revoved those they appear to have gas in them also. What do I do to fix this? Is it a fuel relay or a pump issue?
Oct 8, 2010 at 12:39 AM
  • 75,988 POSTS
You have a problem within the evaporative control system start at the liquid and vapor seperator-inspect vent lines
Oct 8, 2010 at 8:24 AM
