1989 F150 4x4 with 4 speed manual transmission.
1989 FORD F-150
JEFF100970
It starts good but once it warms up it wants to stall and the engine light flickers. It does have a bad oil leak on the timing chain seal. I wasn't sure if it was loosing vaccum because of the leak. Any ideas why it runs rough? It has a 300-6 and the light was red. I think it was only coming on because the engine was going to die. It has 150,00 miles
Jul 4, 2007 at 7:43 AM
JEFF100970
It was the red engine light i think it was only coming on because it was idling low, it would go off once you accelerate. It is a 300-6 with 150,000 miles
Jul 4, 2007 at 11:24 AM
JEFF100970
I will thank you. My brother in law said they have a problem with the MAP sensor also but im not sure. I will let you know.
Jul 4, 2007 at 2:15 PM
