1988 Ford F-150 transmission standard
WISEWAVE
  • 1988 FORD F-150
  • V8
  • MANUAL
  • 175,000 MILES
My 5spd transmission lost first and second gear. I was told the fork can wear and spread. Can I fix the old fork and repair it myself? Thanks
Thursday, March 25th, 2010 AT 8:31 PM
  • 109,885 POSTS
That can be the problem. Does it still feel like it is shifting into 1 and 2nd? Also, as far as you doing it, it isn't a real easy job. If you have mechanical ability and a good trans manual, I would say yes. However, if you are unsure of yourself, you may want to have a trans tech do it. At least it is a 2wd. It will be much easier to get the trans out.
Thursday, March 25th, 2010 AT 10:00 PM
WISEWAVE
No it doesn, t feel like its sifting any thing at all. Does the trans have to come all the way out or can I just lower it and take the fork out the top
Thursday, March 25th, 2010 AT 10:42 PM
  • 109,885 POSTS
It needs removed.
Friday, March 26th, 2010 AT 7:10 AM
