1988 Ford F-150 replaceing engine
CHUCK CLINE
  • 1988 FORD F-150
Engine Mechanical problem
1988 Ford F150 V8 Four Wheel Drive
Hello I have a 1988 ford f150 4x4 with a 351w engine that has thrown a rod. I have a 1988 302 engine I want to put inplace of the 351w will this work and what kind of issues will I have with the replacement. Thanks
Monday, November 23rd, 2009 AT 1:26 PM
  • 110,052 POSTS
First, we recommend direct fit replacements. It should work, but be prepared to have trouble with sensors not matching up, the motor mounts may need changed, vacuum lines will need changed and the wiring harness will be different. When you change anything, everything seems to change with it. That is why we recommend direct replacement parts.
Monday, November 23rd, 2009 AT 1:33 PM
CHUCK CLINE
Thank you so much.
Monday, November 23rd, 2009 AT 1:38 PM
  • 110,052 POSTS
Let me know how it goes.
Monday, November 23rd, 2009 AT 1:54 PM
