1988 Ford F150 rearend
KRIER69
Drive Train Axles Bearings problem
1988 Ford F150 V8 Four Wheel Drive Automatic
Hello im Michael and i have a 1988 ford f150 4x4 and i had a question i got a rearend for it and it has a 3.5 gear ratio and the front has a 3.55 gear ratio. and i know the front and the rear have to same ratio or it will cause problem but will the 3.5 gear ratio work when im in four wheel drive??
Jan 11, 2010 at 3:26 PM
BLACKOP555
  • 10,386 POSTS
if you play in the mud and snow and ice you should be good. but if your on hard ground and pavement it will damage your vehicle in no time.
Jan 12, 2010 at 7:46 AM
