1988 ford f150 knocking sound when driving
OIII88
  • 31 POSTS
I have a 1988 ford f150 302 5.0 liter FI w/373,000 miles on it . A month or so ago. It just died so I put it in the shop . Was told cause was ignition module. Mechanic changed it and ignition coil. Once I got the truck and headed home it started rattling sounded almost like a diesel engine. I took it back and he adjusted the distributor said it was off a little. It ran fine for about 2 days then started making a lifter tap at idle then when driving it starts to make a louder thumping sound. I thought it might be a spun bearing but it doesnt make the deeper thumping unless the motor is under load while driving. I have been told it could be pre-ignition knock from being timed to fast. Could this be the cause or am I over looking something else it might be? Thanks in advance for any help I might get.[color=red:4c7d2d360b][/color:4c7d2d360b]
Mar 16, 2006 at 9:51 PM
LOVESCARS
  • 359 POSTS
If you have gotten that many miles out of a 302 and not had to replace the crank and bearings consider yourself lucky.
Mar 19, 2006 at 2:47 AM
OIII88
  • 31 POSTS
Yeah i have been lucky. Most expensive thing so far was a new flywheel.
Mar 19, 2006 at 2:49 AM
