1988 Ford F150 Ignition switch replacement
150,000 MILES • 6 CYL • 2WD • MANUAL
MARKF150
How do I install the new ignition switch properly? I am having to push the rod with vice grips and the ignition switch is spinning. Do you have any diagrams/pictures that would help? Thanks
Oct 6, 2008 at 8:29 AM
RACEFAN966
  • 5,029 POSTS
what part of the switch are you trying to replace the key and tumbler or the switch near the bottom of the column? Once I know what part you are in question of then I can be of more help.
Oct 6, 2008 at 4:18 PM
MARKF150
Here are some pictures of where I'm at. I have the ignition switch in, but still have to start the truck with the vice grips. I need to connect the switch to the rod, but can't get the steering wheel off. What do I do from here?
https://images.2carpros.com/forum/automotive_pictures/252118_SANY0243_1.jpg
https://images.2carpros.com/forum/automotive_pictures/252118_SANY0244_1.jpg
https://images.2carpros.com/forum/automotive_pictures/252118_SANY0245_1.jpg
Nov 17, 2008 at 9:18 AM
