1988 Ford F-150 ignition switch
CRA71
  • 1988 FORD F-150
  • 6 CYL
  • MANUAL
  • 22,500 MILES
I replaced the ignition switch but it is still hard to turn and does not turn off the accessories or start the truck. Could the rod inside the steering column that engages the switches be broken or out of alignment?
Sunday, February 8th, 2009 AT 10:52 AM
  • 109,885 POSTS
Hi:
Either the rod, as you said, is damaged or the tumbler itself is bad. I would disconnect the rod and see if the key turns properly and go from there.
Let me know what you find.
Sunday, February 8th, 2009 AT 7:32 PM
