1988 Ford F150 Ignition
150,000 MILES • 6 CYL • 2WD • MANUAL
H2200
The truck will start but once you release the key, the engine immediately quits and there are no dash indicators etc. I have replace the ignition switch on the lower part of the steering column. When the switch is in the run position, there is a clicking sound in an inline circuit beaker that runs from the solenoid.
Jun 24, 2008 at 2:34 PM
THELONGROAD1
  • 9 POSTS
Check your cylenoid switch you may have to replace it.
Jul 29, 2008 at 10:34 AM
