1988 Ford F150
1988 FORD F-150
BIGMAN197095
Transmission problem
1988 Ford F150 6 cyl Four Wheel Drive Manual
was driveing down road went to downshift and the shift would not come out of third gear i hold in clutch at a standstill it stays running let t out it stalls like it should just cant get it to shift out of gear
Jul 1, 2010 at 8:39 AM
  • 110,240 POSTS
Will it shift with the engine off?
Jul 2, 2010 at 2:34 PM
BIGMAN197095
[quote:8d67d3fd6f="Jacobandnickolas"]Will it shift with the engine off?[/quote:8d67d3fd6f] no it wont
Jul 2, 2010 at 3:37 PM
  • 110,240 POSTS
If it doesn't shift to 5th gear even with the engine off, either there is a linkage problem or there are internal transmission problems.
Have you checked the linkage?
Jul 3, 2010 at 6:25 AM
