Raise vehicle and install safety stands. Remove hub lock assembly. Tighten inner bearing adjusting nut to 50 in. Lbs. (68 N.M) while rotating wheel back and forth to seat bearing. Apply inward pressure on spanner locknut wrench to disengage adjusting lock nut screw. Back off adjusting nut approximately 90 degrees. 2. Retighten adjusting lock nut to 15 in. Lbs. (20 N.M). Final end play of hub on spindle should be.000-.006" (.00-.15 mm). Install hub lock assembly. Remove safety stands and lower vehicle.
This nut needs to be gently tightened as not to bind up the bearings.
SPONSORED LINKS
Tuesday, April 6th, 2021 AT 12:09 PM
