[quote:6579207e2b="blackop555"]
relays would weld shut if the starter is jammed mechanically not electrically. or if the battery level is low and you try to start it.[/quote:6579207e2b]
What I was saying was neither of these conditions existed. I had removed & reinstalled the starter, even though it had been working fine for a year or 2 before the initial problem. I checked to be sure there was not a lose bolt or something causing it to be improperly aligned. The starter was not jammed mechanically. I charged the battery fully before attempting to restart it after the second relay install. The third relay included being sure the relay was well grounded.
It's fixed now, and I'm happy. Thank you for all of your help.
My point being don't discount the possibility that the starter may be bad, even though it turns over the truck.
Jan 26, 2010 at 3:32 AM
