1987 Ford F-150 Fuel pumping problem
CHUCKFIELD1
  • 1987 FORD F-150
  • 6 CYL
  • MANUAL
  • 190,000 MILES
I am looking at a 1987 Ford F150 that has not been ran for about 3 years. It turns over to start and will start when Starter Fluid is shot into it. But I am not getting any fuel from either tank. My assumption is that either the Pump, Switch, Filter or gas line is stopping the fuel.
How would I check to see which is the problem?
How hard is it to change the fuel pump in the tank?
Tuesday, December 1st, 2009 AT 12:53 PM
BIGJIM79
  • 239 POSTS
The relay may not be coming on. What motor do you have as they have different fuel requiremnets.
Tuesday, December 1st, 2009 AT 2:21 PM
CHUCKFIELD1
It is a straight 6, but I am not certain on the size. The guy that owns it does not remember and I am not close to where it is right now.
Will this help, or do you need any other info>
Thank you, Chuck
Tuesday, December 1st, 2009 AT 3:33 PM
BIGJIM79
  • 239 POSTS
The 6.9liter is a beast in its self. It takes 60 psi to just start it. There are 2 pumps, one in the tank and one under the drivers side door in the frame rail. The one undre the door is the pressure pump. Try grounding the test plug out under the hood. It will be the bottom slot on the right side of the plug. This is a mobile test that runs all the pumps. With it grounded listen for the pumps to come on. If they don't then the relays bad! If they do but still no pressure at the engine, switch to rear tank and clamp the retuen hose off to the front tank as I have seen the valves stick at half open. This makes the gas just flow between tanks and not to the engine itself. The valve is pressure switched. The switch on the dash just changes the pumps from front to rear and the pressure changes the valve route. I hope this helps.
Tuesday, December 1st, 2009 AT 5:52 PM
