1987 Ford F-150
REDNECK100183
  • 1987 FORD F-150
Transmission problem
1987 Ford F150 6 cyl Two Wheel Drive Manual
the tranny inn my truck came out of a 95 f150, is there a 5 speed man. Tranny for an 87 that I can use that will bolt up to a 300 6 cyl? Mainly because the 95 tranny will not let me hook up my speedometer
Monday, February 15th, 2010 AT 5:14 PM
  • 109,885 POSTS
There were 5 speed manual transmission in 87. However, I recommend staying with a direct fit trans so you don't run into other troubles. In 95, the speedo is run by a vehicle speed sensor (VSS). That is why there is no place for you to plug into.
We always recommend staying with a direct fit part because if you dont, there always seems to be other problems.
Monday, February 15th, 2010 AT 11:02 PM
REDNECK100183
I am aware about why the speedometer cable wont work and im not worried about using another tranny, I just wanted to know if they made a 5 speed for an 87. Now about how much would one cost if I was looking for a remanufactured one
Tuesday, February 16th, 2010 AT 2:33 AM
  • 109,885 POSTS
To the best of my knowledge, they did make one. If you find an remanufacturered one, I would say it would be around 1500.00
Tuesday, February 16th, 2010 AT 12:49 PM
