1986 Ford F150 starters
WICKETT01C
1986 Ford F150 6 cyl Two Wheel Drive Manual
i just put in a new starter and starter celinoid and a new batt when i hook up the batt it trys to start on its own i have even pulled the red ignition pulg but it still trys to start its self i also get arcing out when i hook up the batt i hooked it up wire for wire from old to new please help i need my truck for work thanks guys
Sep 10, 2008 at 11:07 AM
BMRFIXIT
  • 19,053 POSTS
Starter solenoid how many connections does it have
check you wiring
S small wire and should have power ONLY when you have the ignition switch in start position
big terminal from the battery with all the fusible links if ant on one side
another big terminal should be straight to the starter
recheck and good luck
Sep 11, 2008 at 7:31 AM
