1986 Ford F150 slippage
PITAMAC
Transmission problem
1986 Ford F150 6 cyl Two Wheel Drive Automatic
before the truck "warms up", i can begin rolling fine and then when i begin to come out of my first turn the trans drops into neutral. itll only happen once or twice per ride and it IS going to happen. fluid levels are fine but i was thinking could there be a compression problem or possibly a pump gone bad?
May 5, 2010 at 12:02 AM
  • 110,248 POSTS
The only thing thing I can say is to check the front pump.
May 10, 2010 at 3:24 AM
