1986 Ford F-150 Ignition doesn't disengage
BSRICKEL
  • 1986 FORD F-150
  • V8
  • 168,000 MILES
I have had the starter replaced three times because sometimes when I turn the key, the starter stays running after the truck is running. The starter kills the battery and shuts off. Last time I was lucky enough to make it to my local mechanic. They replaced the starter again even though I told them it seems the power to the starter doesn't turn off even when I try to turn the truck off with the key.
Help!
Thursday, April 16th, 2009 AT 1:27 PM
  • 110,055 POSTS
Is the starter drawing power or sticking and spinning on the flywheel? Also, has anyone checked the ignition switch?
Thursday, April 16th, 2009 AT 8:33 PM
BSRICKEL
Seems like there is power to the starter because it kills the battery then shuts off.
Thursday, April 16th, 2009 AT 11:58 PM
  • 110,055 POSTS
Check the ignition switch. It sounds like it is sticking.
Friday, April 17th, 2009 AT 2:17 PM
