1986 Ford F150 engine stalls
99,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOOP.K
engine surges then stalls, replaced intake gaskets ,egr,truck runs perfect if tps and idle solenoid is disconnected, otherwise still surges
Nov 19, 2009 at 9:28 PM
  • 110,246 POSTS
Has the check engine light come on? Have any codes come up for the TPS or the IAC?
Nov 22, 2009 at 1:34 PM
BOOP.K
no check engine codes at all
Nov 23, 2009 at 10:00 PM
  • 110,246 POSTS
I would recheck your work and make sure there are no vacuum leaks. Also, check for fuel pressure to make sure the regulator is steady. FInally, have you heard any noise from the catylatic converter (ratteling, hissing...) I wounder if it is starting to plug.
Let me know what you find.
Nov 23, 2009 at 10:35 PM
