Engine Cooling problem
1986 Ford F150 6 cyl Two Wheel Drive Manual
Hello, My truck blew a head gasket and I changed it. The new gasket seems to be working fine. Now it is getting hot.
I took the thermostat out and replaced coolant and water but still getting hot. When I open the radiator cap, I can see water moving so, I assume the water pump is woking.
When I changed the head gasket I did not adjust the valves; I left them the way they were when I took the head off.
Could my not re-adjusting the valves make the engine hot or maybe airlock? Thank You.
Jun 28, 2008 at 4:18 AM
