1986 Ford F150 fuel pump
B122648
Electrical problem
1986 Ford F150 V8 Two Wheel Drive Automatic
would like to find the locatiion of the electric fuel pump. vehicle has dual tanks. hope you can help.
Feb 24, 2009 at 6:57 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:277d7c7b0e="b122648"]Electrical problem
would like to find the locatiion of the electric fuel pump. vehicle has dual tanks. hope you can help.[/quote:277d7c7b0e]
I believe you are going to have 3 pumps on that vehicle...
One High Pressure pump located on the inside frame rail under driver side just ahead of the tank switch.
Then you will have one each Low Pressure pumps in each tank.
Feb 24, 2009 at 7:01 AM
