HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Emission
Smog
SPONSORED LINKS
1986 Ford F-150 emissions
JSPORT1200
MEMBER
1986 FORD F-150
6 CYL
4WD
AUTOMATIC
201,000 MILES
My 1986 F150 failed emissions the CO test results are low 1.27 high is 1.98 any suggestions?
Wednesday, October 8th, 2008 AT 3:28 PM
DOCFIXIT
MECHANIC
Hi
What was HC levels and O2 and NOx also recent tune up and compression test would help in diagnosing a motor with 200K+ miles
SPONSORED LINKS
Wednesday, October 8th, 2008 AT 3:39 PM
JSPORT1200
MEMBER
The HC levels are low 67 and high 33 any help is appreciated
Thursday, October 9th, 2008 AT 11:50 AM
Please
login
or
register
to post a reply.
Related Smog Content
2000 Ford F150 Emission Test
When We Go To Get Emission Tested, Their Testing Apparatus Cannot Communicate With Our Truck. The Guy Says Check All The Fuses Under Hood....
Asked by
maddmaxx58
1 ANSWER
2000
FORD F-150
GUIDE
Smog Test Failure
Smog test time? When a car fails smog it means the emissions analyzed from the exhaust tail pipe is too high, there are missing emission components, or you have a check...
How Do I Get It To Idle Smooth And Pass Smog?
4.9l 5speed 4x4 Duel Tanks Did Tune Up And Replaced Fuel Pressure Regulator. Still Is Idleing Too Rich And Has A Missfire At Idle.
Asked by
FreAkytOasTer777
1 IMAGE
1990
FORD F-150
1988 Ford F150 Passing Smog
No Matter What Gas I Put In My Truck It Seems To Be Running Rich, Bad Smell Coming From The Exhaust. The Exhaust Manifolds Are Cracked Also...
Asked by
richard noriega
1 ANSWER
1988
FORD F-150
2004 Ford F150 Emission Failture
Received The Following Error From The Emissions Test: Rpm=0652 P0506 Idel Control System Rpm Lower Than Expected What Part Is Needed To...
Asked by
Rogersagr
2004
FORD F-150
1977 Ford F150 Emissions
Engine Performance Problem 1977 Ford F150 6 Cyl Two Wheel Drive Manual I Am Trying To Get My Truck Smogged In California So I Can...
Asked by
ancluin
1 ANSWER
1977
FORD F-150
VIEW MORE
SPONSORED LINKS
How to Read Codes
How to Read Codes Chevrolet
How to Read Codes
Online car repair manuals
