1977 Ford F-150 emissions
ANCLUIN
  • 1977 FORD F-150
Engine Performance problem
1977 Ford F150 6 cyl Two Wheel Drive Manual
I am trying to get my truck smogged in california so I can get it registered in my name. But it passed all catagories except the idle catagory it was deemed a grose poluter, as the test was being performed the exhaust was making little chugging sounds that the mechanic explained as unspent fuel, causing it to fail emissions. What could be the cause, and how would I fix it?
Saturday, August 9th, 2008 AT 8:56 PM
When was it last tune -up?
Unburned gas means high HC's
Hydrocarbon failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings.
Saturday, August 9th, 2008 AT 9:03 PM
