1986 Ford F150 Brake Problem
PJASKA
1986 Ford F150 with 120,000 miles.
Brakes were fine unitl front coil spring broke. Brake light on dash came on and truck was hard to stop. I thought it was because the spring coil was broken.
I replaced front coil spring and brake pads and shocks while I was at it. The pick-up does not stop as before. The brake light stays on and the front wheels will slide when I apply brakes. The brakes just don't work well.
What's wrong?
Mar 12, 2006 at 4:40 AM
OLDBAY
  • 9 POSTS
Check to see if the brake lines were pinched or otherwise damaged as a result of the damage or subsequent repair... and bleed the brakes as well.
Mar 12, 2006 at 6:39 AM
