1986 Ford F150
INDYERNIE
1986 Ford F150 6 cyl Four Wheel Drive Manual
I have a 86 f150 pick up 6cyl. The truck was running great and just died. I lost all lights headlights,dash, engine/oil interior etc. The truck will turn over if I short across the starter relay but won't start. Any ideas? I replaced the started switch not the key but the electrial one. cables are good I checked both ends everything is clean and tight.
Jan 22, 2009 at 5:49 AM
PEPPER_12000
  • 5 POSTS
there should be a fuseable link by the battery or the selinoid it will be in the red wire (smaller than the battery cable wire)
Jan 25, 2009 at 3:17 AM
INDYERNIE
Thanks for the reply. I checked the fuse able links they were OK. Three days of head scratching later I found a broken wire going to the alternator. It was a hot wire that effected the entire electrical system.
Thanks for trying.
Jan 25, 2009 at 6:49 AM
