1985 Ford F150 Intermitten loss of brakes
125,000 MILES • 6 CYL • 4WD • MANUAL
AK907COACH
Sometimes the brakes are fine, then there is nothing(no pedal resistance, no stopping power), then they are back, strong and responsive. Could it be air in the line or master cylinder? I was going to bleed them but then they felt good.
Jul 7, 2008 at 6:37 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:92a789277f="ak907coach"]Brakes problem
1985 Ford F150 6 cyl Four Wheel Drive Manual 125000 miles
Sometimes the brakes are fine, then there is nothing(no pedal resistance, no stopping power), then they are back, strong and responsive. Could it be air in the line or master cylinder? I was going to bleed them but then they felt good.[/quote:92a789277f]
Have you had any brake work done recently? Or has the Master Cylinder been Low enough for air to get into the system.
If so Bleed system, However sound like to me that the Master Cylinder is going.
Jul 7, 2008 at 10:32 AM
