ok the clutch plate wore out so i decided to replace the clutch plate and pressue plate plus the two bearings when i droped the tranny i saw that there was only 3 scews holdind the pressure plate on the rest looked like they were over tightend and shered off with in impact so i removed the whole assembly then put in some new screws(now the old ones threaded 3/4 the way up the screw the new ones are treaded the whole way this is all that is differant)when i put the whole thing back together i canot get the cluch to disengage i then blead the line (didnt work)replaced the slave cylender (didnt work)and finally the master cylenderand it still wont work. so far i have droped and reinstalled this tranny 6 times. any ideas?
Aug 29, 2010 at 7:26 PM
