1985 Ford F150
1985 FORD F-150
979REDFRED
1985 Ford F150 Two Wheel Drive Automatic
I bought this truck from an older guy. This truck has been sitting up for about 2 years. It wont crank unless you spray ether in the intake. He said many people tell him its the fuel pump. Can you tell me where the fuel pump is located and if there is more than one?
Feb 5, 2009 at 1:01 AM
HSCBANDIT07
I'm not sure about that year but you should be able to find it by following your fuel line back to your gas tank. If you can't find it then your pump is probably located inside the tank.
Feb 5, 2009 at 2:07 AM
