When I first start my truck an drive it does fine but when im stuck traffic for a long time the engine starts a rough idle up an down then it will turn off then I have to wait 5minutes for the truck to start again seems like when the engine is runnig cold everything works fine
SPONSORED LINKS
Thursday, December 27th, 2007 AT 10:40 PM
BLACKOP555
MECHANIC
Clean out your throttle body and check your IAC module. Also change your distributor cap, rotor, wires and plugs if not done recently.
