Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Flywheel
1984 Ford F150
1984 FORD F-150
ANESBY
MEMBER
1 POST
1984 Ford F150
how do you repair the flywheel/starter in a 84 Ford F150?
Aug 12, 2010 at 11:26 AM
Experienced Mechanic
Can you explaine what is happening? Is the starter bad, the flywheel, or the combination?
The starter is easy to replace, but the flywheel is a big job because you need to remove the transmission.
Aug 12, 2010 at 3:24 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
