1982 Ford F150 Timing Gear/Chain
203,000 MILES • V8 • 2WD • AUTOMATIC
BUCKO1948
What are the number of hours that would be in a flat rate manual for replacing the timing gear and chain. 351/5.8 Windsor.
Thanks in advance.
Jul 18, 2010 at 8:21 AM
DOCFIXIT
  • 18,828 POSTS
Hi
4.2 hrs with A/C add .3 with P/S add .2
Hope this helps
Thanks for donate
Jul 18, 2010 at 8:29 AM
BUCKO1948
does the water pump have to be separated from the timing belt cover? I'm looking to not get double billed if I have the replace the water pump while in there.
Jul 18, 2010 at 8:56 AM
DOCFIXIT
  • 18,828 POSTS
Yes water pump is removed so should only be paying for pump no additional labor
Jul 19, 2010 at 8:04 AM
