1982 Ford F150 clutch
FUNMANTN
Transmission problem
1982 Ford F150 Four Wheel Drive Manual
i need to replace the motor and change the clutch ,can you do that when the motor is out or do i need to take the transmisson out too.
Dec 30, 2009 at 8:39 AM
  • 31,937 POSTS
Hi there,
Yes you can, the clutch is attached to the engine flywheel, just remember to have the flywheel re faced and replace the pilot bearing and the thrust bearing as well.
mark (mhpautos)
Dec 30, 2009 at 10:10 AM
