HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Tires
Alignment
1981 Ford F-150 wanding
JOHANNACONGRESS
MEMBER
1981 FORD F-150
6 CYL
2WD
MANUAL
740,000 MILES
Wandering changed shocks and packed wheel bearings and set toe in
what else could it be
Saturday, September 25th, 2010 AT 8:12 PM
MECHANIC
Is there excessive play in the steering wheel? Have you checked tie rods, pitman arm?
Saturday, September 25th, 2010 AT 11:10 PM
JOHANNACONGRESS
MEMBER
Yes everything on the steering is tight this is what the man who did the toe in said
Sunday, September 26th, 2010 AT 11:47 AM
MECHANIC
The only thing left is the steering box.
Monday, September 27th, 2010 AT 10:47 AM
Please
login
or
register
to post a reply.
Related Alignment Content
Alignment Specs
Hello Could Someone Tell Me The Alignment Specs Of A 1996 Ford F150 Rwd. It Has The 4.9 I6 Motor With A Standard Transmission. The...
Asked by
rmoore09
9 IMAGES
1996
FORD F-150
General Question Regarding Body And Chassis Alignment...
General Question Regarding Body And Chassis Alignment Including Front Suspension And Rear Suspension Alignment. Even When Systems Are Not...
Asked by
Anonymous
1 ANSWER
2 IMAGES
2010
FORD F-150
Want To Put 235/85/16 Tires On To Replace 245/75/16...
I Have A 2004 Ford F-150 Xlt 4x4. I Currently Have 245/75/16 Tires. I'm Thinking Of Putting On 235/85/16 Tires. Do You Think There Will Be...
Asked by
Standfirm
2004
FORD F-150
Switchin Tire Size
I Own A 95 F150, It Has 15inch Tires And Rims, Will 17inch Tires And Rims From A Newer F150 Fit?
Asked by
laradv15
1 ANSWER
1995
FORD F-150
2004 Ford F-150 Tire Size
2004 F150 Heritage Xlt Supercrew 4x4 Tow Package. Will 265/70/16 Tires Fit Without Rubbing Or Causing A Problem
Asked by
jay1126
1 ANSWER
2004
FORD F-150
VIEW MORE
Ball Joint
Ball Joint Replacement
Tie Rod End Replacement Mercedes Benz
